mpfi swap question
so i found the links to do the mpfi swap and it realy breaks everything down, but it seems like i need to change my ecu. my wago is auto and all the info I have found says to use a si ecu but i dont think the si ever came in auto can i use my same ecu?? or am S*** out of luck?
infact, i can most likely get you one for about $40
