help with rims
hi everyone... i would like to put 17 inches rims on my 90 honda civic rt4wd wagon.... i love this ones and i would like to know if this rims will fit on my wagon perfectly, with no spacers or anything like that...
the rims are ENKEI Evo 6 STYLE
17X7
offset:42
thanks
17X7
offset:42
thanks
i'll stop talking.
Shipping takes a little bit to get here but I will let you know as soon as I get them.
The second set was worse because the car wouldn't even move. I didn't know what the problem was so I gassed it and it started to move. I got about 20 feet and stopped the car and saw the aluminum shavings and knew that I was having the same damn problem again. I am pretty sure I could have shaved a little more off with the caliper but it was just easier to change the wheels out again then ruin something. It helps when you have like 10 sets laying around
I am sure I could find a shop that could take a little metal off the inside but I would rather just buy another set of rims to add to the collection.
Find you an Enkei dealer and see if they can help you out with which wheel will fit. I think this is your only alternative at the moment. Maybe see if somebody on Ebay is selling that style Enkei and write to them.
Vehicle Selected: 1990 HONDA CIVIC [Start a New Search]
Factory Tire Size: 175/65-14 | Factory Bolt Pattern: 4x100 | Hub: 56.1 | Offset: HIGH | Lug: 12x1.5
so i just goin to email enkei or actually call them if the rim will fit.... if it does i might buy them for the spring summer and fall time and on winter i will buy like 15 inchs rims or prob 16 rims....where did u go to cut part of the rim??
