cutting out
hey guys,
91 awd/auto, 214k
yesterday i was at a stop sign and the idle went to crap... car didn't die..limped to the edge of the road. put it in park, tried to bring the idle back up .... didn't work...car wouldn't come out of park... shut it down pulled the cap to see if the screw came out of the rotor ... it was fine ..inside of the cap was covered with oil... wiped it down... put it back together.. lit it up and drove away... later at full speed (70 mph)it lost power again..i turned the key off and on again and everything cleared and life was good again ... got home pulled the distributer ..got a fresh one at the parts store... car is still cutting out but flipping the ignition switch clears it for a time.
does this problem sound familiar to anybody? is it an ecu giving up?
thanks
91 awd/auto, 214k
thanks
check your ecu for codes.
if you dont know how to do this then follow these steps:
-the ecu is located under the pass. side carpet. pull back the carpet.
-you will see a bronze colored metal plate. the ecu is under this. there will be a small window on this plate. under the window is a little LED light that blinks codes.
-count the blinks. if it blinks 4 times then pauses, then blinks 10 times, pauses, then repeats 4 times, then 10. etc means that you have codes 4 and 10. you could have less or more, it all depends. anywho, so get this numbers.
now that you have the codes check this link:
http://www.hondacivicwagon.com/board/vi ... .php?t=671
hope this helps.
since i replaced the distributor this am i suspect those are lounging around..and 16 might be the issue ....
thanks for the quick reply!!!!!
9 = #1 cylinder position
16 = fuel injector
#4 and #9 are found in the distributor. In most cases, replacing the distributor is the only alternative. if you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
#16 means you have a bad injector which could be a cause of the sloppy engine performance.
while this is all fine and dandy, since you have replaced your distributor you might try to reset the ECU... do this by unplugging the negative battery cable for 30 seconds. if you have a spare ECU or someone who can lend you one you might try to see i it reads the same codes. it is quite rare for a Honda ECU to fail so this is probably not the problem. anyways... yeah. good luck.
btw is your car running ok right now?
A common fault over here with the B16 CRX is that people change for an aftermarket header and get the two O2's the rong way round.
ith an OEM there isn't much notice but with aftermarket probably because it flows better you will get hesitation and a slight misfire on part throttle in closed loop mode.
Often this codes as an O2 fault but sometimes you'll get wierd codes like injector or dizzy faults.
It's interesting to see the same thing hapen with a single O2 going faulty.
thanks for all the help !!
