Gearbox bracing
Ok, I've heard about draggers bracing their boxes to keep them a bit stronger. I know someone on here (sorry forget the name)( split their box around the diff area.
Has anyone looked into bracing for large power or have any good links on D series bracing solutions ?
What about cryo?
Does anyone know if the shuttle box has steel caged bearings ?
The Y1/Y2 boxes don't, we tend to do that to them when we rebuild them over here.
What about cryo?
I had an idea about how to fix it........only afterwards the tranny won't be able to fit back into the chassis, oops!
I've seen before people pulling the 5th from a drag box in a B and putting bracing in that way.
Looking at cyro and WPC treatments over here. TBH I thought it would be expensive but it's not that bad.
I know of a guy that does NDT looking for cracks and damage in the gears so probably give him a shout too.
It does nothing for the thrust loading, basically the countershaft trying to exit out the end of the case.
About 400 whp is where you start stripping the gear teeth. There is a guy on HondaTech that has a coating, but that will not prevent axial walking of the shaft.
Go much beyond 400 whp, look into an adapter plate to run a B series tranny.
