Motor is dead again.
Well it just stoped running. Its geting spark, fuel, air. Timeing belt good.
It will Burp if you let it sit. But it wont fire. Just cranks
Also my other wagon the brown car has a broken Camshaft. :evil:
you sure its all happening at the right time? is your timing correct? you positive you're getting fuel?
ECU codes??
Yep its geting fuel.
I think your right its something with the timeing.
Its it possible that some how the timeing could slip?
code 1 = O2 sensor
code 4 = crank angle sensor (inside dizzy)
code 8 = Top Dead Center sensor..
codes 4 and 8 mean you definitly have messed up timing somewhere. could be inside the dizzy as well (faulty dizzy).
im thinking it might be that your timing belt skipped a tooth or two.
But i still think it would start and run even though the dizzy is off.
It's late now but tomorrow morning ill double check the timing belt and see if your right. I hope it that simple, or more simple then that cause I hate doing timing belts!
I cranked it a couple of time with the head off and every things moving and the timeing belt is good.
Hun well its being sneaky. I left the ket on run w/o the motor runing and i heard a quiet high pitch sound coming from the rear of the motor. or is that the injection unit or someting to do with it?
