Problem with 5th gear
Hey in new to this forum.
I took apart my shuttle 4wd gearbox to clean it and swap the cable VSS for a electrical VSS ( to do that i had to remove the mainshaft(just removed it) and dif. Then put everything back like shown in the manual.
I did not test with the shifter if everything was working. After reinstalling the gearbox i try shifting all other gears work exept the 5th. Its like there is no 5th at all.
has anyone had this type of problem? Do i have to remove the gb and take it apart again ? Or can i do some other test first?
Im gone remove the shift arm cover of today and see if the problem is there.
Maybe check the shifter????
