Hey guys, i was wondering if it'd be possible to do a b series swap with the factory transmission in my rt4wd wagon. Or if there is maybe a manual 4wd b series transmission that I could use in it's place?
If your wagon is stock it has a D series motor. That would be a no on the B swap with the stock tranny. You can do a B swap with a CRV trans. Check out Turbo Teg's post for all that you will need.
