Heater box leak leak? Water passenger floor when it rains
Water puddles on right side below glove box after a rain. Not a huge amount, but enough.
So far, pulled the wipers, the large plastic cover and the rubber dam.
Cleaned out the area where water runs down the windshield and is supposed to exit the car below.
Turns out a rat had been living in there at some point (I've been breathing that in for 3 years? Disgusting)
Tried using #12 coated electrical wire to clear the drain but not sure I accomplished it.
Shouldn't have started this project with rain imminent as had to quit and tarp it.
Question:
Can't tell, where could the water be getting in? This model Honda doesn't have the heater box intake open to the engine (a common cause in other models) so how can water get down there as there is a black plastic cover (afraid to remove for fear of breaking it) over the access.
Also, any idea where I get replacements for the little black plastic rivets and caps I've broke so far?
Thanks for your advice!
Question:
Where I live on rainy nights I don't park down hill to the right.For some reason water enters the same way as yours.I park in the same spot ,but back up into this tiny dip & it's ok still facing down hill to the right.
Check teg forums for more info.
Another possibility is maybe the cowl cover seal maybe leaking if there's one?Causing water to drip off the cover into the vent hole.
