First, try pushing the hood carefully around the area wher the lock is, while someone else pulls the lever. If it works, you have to re-adjust de lock by screwing out/in the pin of the lock. (the one with the big spring.)
If it doesn't work, your cable is probably broken. Then you have to dismount the bumper, en try reaching the lock from inside to open it.
yeah true that i did , well i also sanded and painted the bumpers and the little plastic thing where you put the licence plate looks badass man ! :twisted:
