and I suppose there's a code list somewhere that decodes the flashy lites to explain what they mean? now, I'm just assuming there's more than a few. I know the OBDII has something like 500+ codes and I have one of those readers.
and what's the diff between and ECM and an ECU? module? unit?
i really hope that helps...i was searching first on the old board, but couldnt find it. but then i did some research of my own, and thats what i came up with....have fun counting
In the middle of the plate should be an LED, thats the LED that flashes to tell you your engine code if the check engine light is on.
...jm.
http://www.guaranteedphresh.com/~vulcandan/car/ecu.html
