Reverse Light quick help needed>please
Hello folks,
Anyways just pick up a 91 honda wagon but unfortunately I just found out that my reverse light is not working.
Anyways I check the bulb and it seems to be fine. All the lights are working except for the reverse light. Not sure where to pin point the problem. I have n't check the fuse yet tho?
Another question is the signal light beside the headlight suppose to blink when turning? I notice that mine is not working but the bottom part signal is working.
I'm fairly new to Honda any help would be much appreciated.
Thanks in advance.
Thanks in advance.
if i confused you i can take pics for you, haha..
the screw is circled in red.
then the blue arrows show how you have to take out the corner light.
ok, maybe sometimes... but just point fingers at Kahuna :x hehe jk
1. Change the bulbs (not a big deal)
2. Change the fuses (not a big deal)
3. Reverse light switch (big deal don't know how0
So can anyone give me an idea of how to work on the reverse light switch. The car was an automatic transmission before which was swap to a 95 5 speed manual transmisson. Is this a hard thing to be fix?
I was just about to ask where is the switch located..LOL your fast dude.
:roll:
No go eat your fruit loops like the rest of the good kids..
Haha
I haven't really look into the car ever since bought it's just park right now and I have'nt really drove the car yet. I'm trying to get familiarize with it.
the switch is on top of the transmission by the starter. it doesn't LOOK like a switch of any sort, it looks more like a rubber o2 sensor. there are two wires coming out of it, one has a male and the other, a female end. the sensor is covered by a rubber boot and screws directly ontop of the transmission. looks like a 5 minute job.
hope that helps.
the reverse light switch on an auto was located under the auto shifter plastic. a 12 pin plug with #2 and #3 terminals controlling reverse lights.
my guess... you might try and go without reverse lights hahaha
Kahuna, suck my balls.
http://rywire.com/store/faqdesk_info.ph ... 228a197202
That might help.
awww i wuv you too
I read the instruction here again and again but I just got so frustrated with my wiring. Seems to be easy but my wires looks like a mess to me.
Please see below and explain me by detail what should I do. I'm sorry if this problem had been an inconvenience to anyone.
as far as the switch location, it is here:
the bluw is where the switch is, the red is the wires coming from it.
I will be able to help you more on the wiring tomorrow when I get off work.. I gotta get some sleep though..
