cuts out between 75-80mph
Question guys: 91 dx wagon manual with b18c gsr and b16j1 trans.
Cel codes 14(Iacv), 10(iat), 9(cyl 1 position sensor) and 41(o2 heater)
My problem: cuts out between 75-80mph in 4th and 5th gear on highway. Feels like fuel cut. I can rev out 3rd past 80.
When I had this engine in my 88 sedan last year (same harness and everything) I had only code 9 and it ran flawlessly. Which code could cause this problem?
Thanks for the reply. I drove with code 9 for almost a year with no drivability issues. Im thinking the IAT sensor is the main issue. Ill check wiring again then maybe replace sensor.
