6 speed tranny in an 89 dx hatch, will it work
i want to put a manual in my hatch, it is now an auto, its a 89 dx hatch the tran does not change from 2nd-3rd or 3rd-4th all that great its getting to were it wants to rev up between gears an i figure the tires are gonna kill the auto trannys any way,
i would like to put the 6 speed wagon tranny in it,
my question is will if fit because of the awd part of it, i dont want to make my car awd i just want the tranny for the low first gear,
i know it will bolt to the engine but i was worried somthing else would cause a problem?
does it use different axles then my car has?
would any pedal manual asembly an linkage out of a hatch work or does it need to be out of a wagon?
i just want to know of any things that would cause problems or reasons it would not work
thanks for any help
thanks for any help
yes the AWD tranny has different axles.... also, im not sure it would work without the rear driveshaft all that well, but im no expert and am prolly wrong, haha (usually happens that way).
pedals and cables and such would work from a hatch. what you would need (assuming you can use the AWD tranny) is a cable shift linkage from a RT4WD wagon.
honestly i would just put in a DX or Si tranny from a 2WD civic. plus those trannies are really easy to find and are plentiful vs. the AWD tranny. um, and its an easier swap to go manual as well.....
i'll let everyone else tell you im wrong though
not sure though about the AWD axles.. someone else needs to back me up on this.
EF,CRX DX & ZC________________3.88 Final drive
EE(wagon)&EX(sdn)(thx.Davens)___4.058
CRX SI________________________4.25
but there was some talk of the awd beind a 4.4 not a 4.0
The 2WD is 4.O58.
If you want to do a 4WD tranny swap.There's a member on here that did the complete swap into a CRX.Do a search.
where is the DX 3.722 and HF 2.95?
The DX 3.722 is for 96+ Civic &
the HF 2.95 is for 49-state(USDM).
Been there done that many times!!!
Cheers!
P.S Besides that when my waggy was in 2WD mode, I was getting worse MPG that now...when I put it back in RT4WD mode...Loving it!!!
Incorrect.
88 Civic/CRX was 3.722, 89-91 is 3.89 and I'm finding the 88 HF was the 2.95, 89-91 was 3.25.
I'd also explain that the 88-89 doesn't use the 1mm spacer was were as 90-2000 does next to the thrust washer on the mainshaft.
But then correct info just confuses the masses
the HFs were only available in the CRX.
i think (??) the 4WD tranny had a half shaft, so that both left and right side axles were the same length....? if it did then basically thats the difference between the 2WD tranny axles and the 4WD.
if you swap out for an HF tranny you can just get regular Civic or CRX axles for your car.
