Got F2 Full Coil-Overs on Wagon, but Have Spring Rate Qs...
Hey all I recently purchased a 90 wagon that already had some nice 24-way adjustable full threaded body coil-overs on it, and while they are nice the ride is STIFF.
This is my daily driver, so I want it to ride more smoothly. I'm basically looking to see what kind of spring rates you guys have used with success in terms of riding more factory like.
Right now the wagon has 11K front, 6K rear - honestly I'm kind of clueless on what that means lbs. wise. I'm used to saying and understanding 550lb. or 350lb. rates.
Anyways I'll bascially be looking for some Eibach ERS coil-over springs, but I want them to be a good bit softer than my currents. I'll just turn the dampening all the way to soft.
It's either that or sell these very nice full coil-overs, hunt for some KYB Gr-2 wagon-specific shocks, and then some wagon-specific Tein S-Tech springs.
I'm very wary of tossing on shocks and springs intended for a non-wagon EF. I also know that when using standard lowering springs you're rolling the dice for ride height. Sometimes it's uneven, and man I really, really hate that.
Any help would be appreciated.
Unless you use EF hatch shocks, not wagon ones.
it rides very smoothly though, slightly stiffer then stock of course but for a daily i highly recommend those. (my wagon is a daily as well)
mine cost me $660, idk what your budget is
here is a thread on honda-tech about spring rate conversion... not sure how your F2 springs are labeled, but maybe it will help.
http://www.honda-tech.com/zerothread?id=1633963
You mean the rear wheel guard sits higher than the front? With the EF shocks the chassis itself should sit basically flat.
Which Teins? Basics? You're saying you can get the car level if need be, but basically you have to set the fronts a good bit differently than the rears to do so, right?
I don't mind that honestly, as long as the changes don't reduce the travel to where it can bottom the dampener out.
i just had my rear higher because i take people with me all the time.
