Idle/acceleration trouble
Hey everyone. I am having some idle/acceleration problems. It idles low and has also died one me. Also, when I am at a stop and press the accelerator, it almost dies but then goes. Other than that it runs pretty smooth.
I have had a lot of recent work done on it. Within the last couple months I have replaced the piston rings, head gasket, timing belt and tensioner, water pump, thermostat, radiator and idle air control valve. Before I replaced the idle air control valve the engine would rev up and down. It has helped that. Now it's not idling right.
Any my ideas where to go next with this?
thanks in advance
thanks in advance
bought a car from washington had oem o2 on it and it was barely running consistantly try that ( make sure you get ones with plugs already
and did you replace with a brand new or used / refurbished ICAV
