HELP!! DOHC ZC Swap into RT4WD SOS!
Hey guys! First timer here, just bought a 91 RT wagon a couple months ago, little turd had almost zero compression so I bought a DOHC ZC and swapped it in. It will start but for seconds at a time. Im getting code 15.
Does anyone have legit wiring instructions for repinning the dizzy?
I keep getting broken links to thezcr or whatever that epic website was.
I used the harness that came with the DOHC ZC and rewired the plug on the driver side. I have two extra wires, I need this car for work way bad!:mad::mad::mad:
ANY HELP IS GOD SENT. THANKS IN ADVANCE!!!!!!!
[IMG][/img]
[IMG][/img]
2) give WireWorx a call and see if they can help since they do it for a living.
Also, directly above this is a sticky that has a thread on the swap.
Can you post photo's of the wiring in question? Maybe a video of it turning over, on and shutting off?
I thought the DOHC ZC into an RTAWD wagon was plug and play except for the distributor since the cam sensor is on the cam on the DOHC engine and in the distributor on the SOHC engine. Is this correct?
More details please about your wiring changes.
