Broken timing belt repair advice needed!
Hi all,
I join today bearing the sad news that the timing belt on my buddy's Wagovan (D15A2) has snapped. I already have the head off, and have confirmed that there was piston to valve contact. The pistons look like they're okay; one has a little bit of damage, but nothing that will interfere with the valves in the future, and no chunks or shards missing.
My question is: after a trip to the machine shop for new valves, guides, and seats, is the rest of the engine okay? In my experience, it should run fine with a couple scuffed pistons, but I'm really not very familiar with Honda engines, so I don't know if these D15's have really weak rods or bearings that could be wrecked by piston to valve contact.
The D15 rods are a little shorter than a6 rods which makes up for the different stroke but I don't know if they are any thinner. I think your best bet is to slap the rebuilt head on and hope for no bottom damage.
You could also just drop the oil pan from the bottom and take a look up into the block. You might be able to see potential rod damage.
