rt4wd driveline issues
i broke the front drive shaft U joint. im looking at $$$ to have it Frankenstein repaired or buy an used one at almost the same price to run the risk again of it failing. is it wise to just delete the middle of the drive shaft. have a strait shaft from front to rear, eliminate the issues of the driveshaft without the flex joint that helps keep the shock of the engine sway from the rear transfer case? all repair parts are discontinued. am i able to use a crv driveshaft if shortened as a replacement?
