Dry cell battery + relocation kit? Whats everyone running?
I'm looking to get some info from folks who have dry cell batteries like odyssey brand which model you went with and the expected life span of the battery.
Let's see your setups!
started my wagon in the middle of a night during a road rally a -20 F. 2lbs. put it wherever you want.
haha that sounds bad ass do you have any pictures?
do you have to have it recharging when you arent using it? or disconnect for that matter? sounds too good to be true!
use like a normal battery. just dont expect it to run your headlights and stereo for 20 minutes and then crank.
thats crazy is it really only a few inches wide and tall?!
how long have you been running it for?
yep, its that small. but they have some in different dimensions so pick what fits your relocation spot the best.
Mine is actually the 12Ah size but id recommend a little larger, or as large as your budget allows, the 36ah ones are like $350 but the weight is still only 5lbs! ive had it in the car since october of 2013, which is better than any optima ive ever owned too.
