Suspicious Smog Check Dude?
Does this sound shady? I went to have my wagon smoged check today because i sold my wagon and wanted to give the buyer a new smog check. The technician did a "pre-check". Then he said he is unsure if it will pass or fail. So he lifted the car and started touching around the catalytic converter. So after that he did the test, and it failed! Then he said I needed a new cat and it would cost $450. WTF! I just had this wagon tested last November and it passed with flying colors, way below the emissions limits.
Spend an hour under the car changing it.
I have one on my 90 FWD wagon. I've had it on there for 5+ years. I paid a bit less for it (closer to $100). Never an issue passing emissions.
My original was melted due to timing/fueling/misfire issues and would not pass smog check. I actually pulled it off and checked before buying a new one.
Not sure how different TX smog checks are vs CA except my car just aged out of smog checks here ...
Not sure what someone would do to cause your car to fail. Can you get a 2nd opinion?
Also I assume he was saying that it was $450 and they could install it for you?
Do you still have the numbers from the previous check?
Also, just as an FYI, it could have been the previous place fudging the numbers. http://articles.latimes.com/2010/feb/25/local/la-me-smogtest25-2010feb25
p.s. get out of California =D
