(a6)crank pulley question?
well i have a 91 rt4wd with the stock d16a6. well the crank pulley fell of on the freeway coming home from work one night. i got one from a 95 civic si and bolted it up. it fit fine accept it sits out to far and the alt. belt doesnt line up. now in the process of hunting down a stock pulley i've ran into a problem. some a6 pulleys came in a 22mm diamiter and other came in 24mm. is there any way of telling the size of the crank pulley by year/make of motor, without wripping the pulley off and messuring it? it's 4* outside in south eastern wisconsin and i dont have a heated garage to just pull a crank pulley off.
no no. i'm talking about the inner diameter that goes around the crank.
