Engine Mount - 89 RT4WD
I recently got a clutch job on my wagon. Everything seems pretty normal, but I have a question. The mechanics said my front engine mount was damaged from a fender bender I got into a couple years, and that they couldn't use it when they reinstalled the trans. They said it's really not needed. Is this situation OK or what?
most of our wagons have ruined the bushing in that mount and are essentially running without the front mount.
so you will be fine as long as your other three mounts are in good shape
infact, Hasport kits illinimate the front mount altogether, it is just a small one that you dont really "need" if its gone anyways...
Like eldonciv777 said u could put in poly inserts or fill them w/polyurethane from a tube.The prob is increased vibration.
I've wurked with a lot of options for the front mount.
The hasport kits are much more solidish than oem, that is why they don't need one in the front.
If you front crossmember is it good shape (not bent or whatever) and it lines up ok, just get a new one. They don't cost much and the car will drive better.
