88 rear hubs/trailing arm on a 89-91 RT?
I have searched this site and other sites and I am seeing conflicting info. Need to know whether a 88 rear RT hub/trailing arm is the same as 89-91 RT. I know the 88s have some different pieces. I have a trailing arm, so I really just need to know if the 88 hub will mount correctly.
Thanks,
Thanks,
Anyone else have have concrete facts?!
91 Right trailing arm - 52370-SR7-A10
Honda has them listed as the same part number. I don't see why they would not interchange.
The 88 did have a different lower arm that the shock bolts to. It used the Integra type r style with the shock having the eyelet. Where the 89-91 the shock has a fork around the lower arm.
If it's the same part number I think you're set!
if for some weird reason it doesn't work, I'd reply here for others in the future. and if it works if do the same just to be 100% sure!
good luck!
Haha!! I never thought to check PN's! Alrighty then, I will try it out and let you guys know!! Thanks for the responses, much appreciated.
I had always wondered what the best method was to add a rear SB. Good info, thanks!
