Removing the bullbar...
Ok. Made a mistake of thinking this would be relatively straight forward. Bought some new t-style hex keys for $60, thinking the bolt heads would easily come off underneath. This however is not the case as its managed to strip a bolt head. Shight.
So I thought ok, have a bit more of a look, found the bracket that bolts to the body is held by 3 x 14mm head fine bolts. Left side near the battery was relatively easy... right side however is looking like I'll have to remove radiator/air con unit. This I don't want to have to do at all.
Can anyone shed some light on how they went about removing their factory nudge bar? This appears I'm over complicating it.
Thanks
Mark
Thanks
Mark
