DPI to MPI swap
I will try the swap next weekend. My question is can I use injectors from 92 1.5L engine or do I have to use the stock injectors with the resistor box? I have a partial wiring harness from the 92 1.5L engine to include the injector plugs and the junction connector for the injector ground wires. I will be using the stock intake manifold and the distributor for the 1988-1991 1.6L engine. I am using the PS9 Ecu since it is an automatic tranny.
