200K service = reduced throttle response?
Hi all, last weekend I went ahead and did a 200,000 mile service on the Wagovan as it's new to me and the T-belt was of unknown age/mileage.
Where the car used to have rather impressive and spunky throttle response, it now bogs, requires about 800 additional rpm to smoothly roll from a stop, needs WOT to actually pick up any revs and feels considerably down in power.
So i'm asking you all, the best and brightest, what could possibly be amiss with the throttle and what would you do/check to regain the throttle response that seems to have disappeared for no reason????
New parts installed:
Notes:
- Timing belt
- accessory belts
- tensioner
- water pump w/gasket
- spark plugs (oem heat range)
- valve cover gasket
- upper/lower spark plug gaskets
Notes:
- T-belt was installed at factory spec of TDC on the cam pulley and white mark on the lower pulley.
- Distributor has already been advanced as far as physically possible, this is the only way the car is actually able to accelerate at all currently.
- Not enough care was taken with the camshaft while removing the valve train in the lower plug seal gasket install
- There was an ENORMOUS amount of oil in cylinder plug hole #2 (from left to right), the others showed the usual small amount. She smoked like a beast at start-up while burning off the oil that went into the cylinder during the work.
- Throttle cable was not adjusted and has just a hint of play in it (~3cm)
I used to have a picture but lost it over the past 7 years. It's easy to have the top sprocket off one tooth.
i second this. My 1.6 was off a tooth (did not time using the timing cover), and sounded exactly like your symptoms.
