Problem removing door panels...
How is the top of the door panel attached to the door? I am having trouble removing it. I removed the top side screw, the screw under the the door latch, the screw in the door jam, the screw on the back of the bottom map holders, and the screw in the door handle/cubby. Are there any other screws on the top of the door panel that I am missing?
The previous owner must have glued the top of the door panel on or something cuz it's not coming off after following those instructions
