new wagon gonnaa need some help!
Hello! I recently became the owner of an rt4wd with a knocking motor. I'm looking to get this running by winter. Hoping you guys can help me out with some info along the way!
It's a 91 rt4wd with a dohc zc in it. I've ordered a sohc zc as a replacement. While under the car I noticed trans fluid coming from the plate on the transmission, which I've come to believe is the tranfer case. I've been reading that the bearing are often the cause of this. What parts and seals are generally needed for this repair?
I noticed the distributor has a vaccum line on it does that mean i need to replace it with a si distributor?
Also should i pull the old motor and transmission together to make it easier?
Thanks for any help
