My new basketcase rt4wd
Hi all,
Im Bill from md and i just recently picked up this RT4WD for cheap in an attempt to save it. I'm going to be chronicling my adventure trying to sort out some of the previous owners "Improvements" (i use the term lightly) but it is a 91 5 speed, d16z6 swapped and the transmission, engine and 4wd seem to be in very good order.
I dont have too much Honda experience ive done some work on a eh hatch, I mainly deal with the older watercooled VW's, so this should prove to be a learning experience!
On to the pics!
The bad stuff: Broken rear window, Broken driver window regulator (already got one), speedometer doesn't work, but that all pales in comparison to the attempted "Wire tuck" on the car....
obd 0 to 1 harness... what a mess. Throws a vtec pressure sensor code.. because the wire wasn't attached to anything..
Crimp connectors.. exactly what we want to see in the harness.
Engine bay box stuffed under the dash.
No idea what this is going to, but its hot and is exposed, coming from AC fuse on the box (ac is removed.. along with heater core.. why....)
wires jumped with a 2 foot long piece for no reason...
power distribution! First major thing being addressed. Battery was moved to trunk.
Bad ground which prevented the car from starting when I looked at it.
Wipers? Just cut it.
Same with the reverse lights.
Anybody know what these are to??
Then on to the body:
Creased hood.
Bumper Gap
Bacon Fenders.
The good stuff??
d16z6 a bunch of aftermarket parts, no pcv hose? I found one in the glove box with the nipples and plugs...
Brake lines tucked
Hidden prop valve
F&F type 2, adjustable Uca's and toe rods.
Parts found in the back seat. Diff mounts and crossmember bushings
Speaker pods no grills.
Some random seats??
I think this is going to be my best friend through this project
    Welcome along. :)
  • Welcome to the board. You are an american hero for saving this wagon
  • Welcome, seems like a nice project car, I am glad you saved the wagon, these are rare, and when you fix it up I promise it will turn ALL the heads your way.
  • Nice save!!
    Welcome to the wagon life!!
  • bertoberto Band Wagon
    Picked up a drivers front window regulator from amayama.com. Came in a week, half an hour and it was in.
  • I hope that brake line tuck was done with more skill than the wire tuck. SCARY.
    Will be a great car with a little love!
  • You picked a good one! Lots of patience and a bit of money will get it back into shape. Welcome!
    It seems the brakes were done before the last owner. They look fairly safe to me.
    Been a while since I posted. Things are coming along on the wagon. Not as fast as expected but I haven't had much time to work on it.
    All front harnesses re-done and re routed.attachment.php?attachmentid=3203&d=1447211838
    Ripped out all of the old power cables. This was the connection between the battery, fuse box and alternator... Quality Work.
    Finished rerouting and wrapping everything in the cabin, moved the fuse box and put some power distribution blocks.attachment.php?attachmentid=3199&d=1447211660
    had some down time waiting on parts so I refinished the wheels.attachment.php?attachmentid=3201&d=1447211660
    Polished them up after that.. apparently didn't take a picture.
    Rewired the wipers, they work except the intermittent. Car came with an extra wiper switch so I'm going to check that.
    Next i have to make a battery mount in the trunk.. nothing seems to fit beside the trap door thing for the spare.
    Then it needs a ball joint and replacing differential mounts. Going to fit a universal heater/defroster under the dash.
  • mistahjoemistahjoe New Wagonist
    keep it up. awesome work.
  • great work, i'd hate to tackle that wiring
  • Madr0xMadr0x New Wagonist
    Good job cleaning the wiring up but there is nothing wrong with crimping the engine harness. Honda does that from the factory.
    Madr0x wrote: »
    I agree that some crimps may not be a big deal, however when i went to start the car go move it into the shed, it would not start because one of the wires had came free from the crimp. I gave the few crimped wires a tug and 2 of them came right out. That was when I decided any wiring that had been touched was going to be redone.
  • Wow, just wow! Good on ya for taking on that mess. Counting myself lucky for finding 3 of these that are worn, but basically stock and unmolested. The seats look like CRX Si. Welcome and congratulations.
    berto wrote: »
    Oh well that isn't any good haha.
    Started it up today for the first time since I ripped all the wiring apart. Getting a code 8 tdc sensor code. Going to look at the wiring and test for open faults.. if its not that I guess its a distributor issue?? Also speedometer and vtec code fixed!
    Found more bad connections further down in the distributor harness. Just twisted together and taped. No more code 8!
