DIY/Tutorial : Passenger Seat Foam/Fabric swap onto Drivers Seat!! (PICTURES)
 MrJayDM
                Wagonist
MrJayDM
                Wagonist
                    Here is a DIY/Tutorial for swapping the passenger seat foam and fabric onto the drivers seat.
I'm not going to go over how to remove and disassemble the seat it self.
In this tutorial I will show how to remove the seat foam/fabric.
I personally removed the fabric from the foam because I wanted to wash the fabric.
This is not necessary, I you want to remove the fabric refer to my build thread here
https://www.civicwagon.com/showthread.php?19215-MrJayDM-RT4WD-Restoration-Build-%28Ton-of-Pictures%29&p=230183&viewfull=1#post230183
Starting with the back portion of the seat!!
Once you remove it all just follow the directions in reverse.
Next The seat portion of the seat!!
Here is the complete project!!
It was really easy, but time consuming!!
Make sure you take your time and be careful not to brake or rip anything..
