is 59300 comp camshaft for my d16z6 worth it?
Here is how the engine looks now:
Here are the current engine specs for those of you that have not read my thread:
- D16z6 Engine.
- P29 pistons (12.5+ compression expected).
- 75.5 bore.
- H22 Throttle body (60mm)
- all new seals, belts, rings, bearings.
- new water pump.
- valve seating job.
- NGK BKR6E spark plugs.
- New spark plug wires.
- 3" intake w/ pipercross filter.
- 2.25 exhaust with 4-2-1 manifold.
- Exedy clutch.
- Oil catch can (catches both from pcv and head ).
- P28 ecu.
The car is currently on the engine break in period (400 miles in and 600 more to go).
So today I got an offer to buy a used comp camshaft 59300 for ~ $140!
I have had mixed feelings reading online about this cam, but so far this is what I have got from it:
- The cam makes more power and pulls stronger until redline - 7200/7400 rpm.
- The cam does NOT need upgraded valves/springs/retainers if it is not boosted or revved way above the stock limiter.
- The cam does NOT make power after 7200 rpm, so it is not worth revving it much higher.
- The cam is said to make excessive noise at idle.
However, having all that said I think it probably is worth to buy it and drop it in before the dyno day.
What do you think?
- D16z6 Engine.
- 75.5 bore.
- new water pump.
- Exedy clutch.
- P28 ecu.
What do you think?
If your willing to do the work it needs to get it in and it's not breaking the bank I vote yes swap cam
http://www.superstreetonline.com/features/sstp-1007-1995-honda-civic/
Might be worth a gander to check out the level 2 or level 3 bisimoto cam. I'm going with a 2.4 for my build.
But I just love the na feeling and that screeching sound coming from the front of the car as well as the intake. That is also why I got a super quiet exhaust.
