2wd or 4wd for dyno tuning?
I have heard mixed opinions on turning off the 4wd system to save viscous couplier for dyno tuning. What have you guys done? Also would keeping it in 2wd mode still incur more drivetrain losses than regular 2wd car? I mean is the driveshaft not spinning while in 2wd?
Any info is appreciated.
Keep in mind that unless the prop shaft is removed it will turn with the rear wheels.
I'm unsure of what you are trying to ask. Are you wanting to dyno tune on a 2WD dyno with 4WD still engaged or are you wanting to know if it would be better tune the car in 2WD or 4WD?
Since you are wanting to tune the car, all you need to do is put the engine under a simulated load. The Dyno can do it in either 2WD or 4WD.
Most 4WD dynos have the two drums connected, so the only way you'd put stress on the VC is if they front had traction issues. Otherwise, it wouldn't have made a difference other than showing a lower power number.
