k20/k24 clearances
i have seen a few wagons k swapped now and fitting under a stock hood so my question is what is the ground clearance with these 2 motors swapped in? for an rt car more specifically. im thinking about going k swap over my current b swap but want to make sure i can still sit at a lower height.
post #13
ya thats the lne. how come when i search it always says no topic found or somethin like that???
and thank you
Or you could try to talk to Brian ee4 he is doing a k24 swap. https://www.civicwagon.com/showthread.php?14949-Brian_EE4-s-RT4WD-stance-build&highlight=brian+ee4
Also there is austinsb but I am not sure if he is still active. https://www.civicwagon.com/showthread.php?8180-K20-Swapped-Wagovan-Build-Ohio&p=228071#post228071
