toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Electronics, Fueling & Air Conditioning
Adding VTEC to non-Vtec
FluffySticks
Band Wagon
June 2015
in
I have been wondering if it is possible to add a vtec 'computer' to my 1.5L? What would need to be done to have this done.
is it even possible?
turbo_teg
Council Member
June 2015
Its not just the computer. Head is different as well.
bkmc24
Senior Wagonist
June 2015
turbo_teg
What he said. It requires the right head, which is most important, the wiring for the ECU, the ECU itself as well as oil passages and lines.
MrJayDM
Wagonist
August 2015
I have a a6 with a P28 running.. Runs just fine..
I got all my parts from a 92-95 Civic ex with z6
1) OBD0 to OBD1 ECU Conversion Jumper Harness
http://www.ebay.com/itm/OBD0-to-OBD1-ECU-Conversion-Jumper-Harness-For-Honda-Civic-Acure-Integra-CRX-/391173712840
2) OBD1 ECU I would suggest a P28
3) OBD1 Distributor
4) 4 wire O2 sensor
NOW if you actually want vtec!!
You need a Vtec head
z6 or y8, I would suggest z6 head.
You will have to run the vtec wires from the Jumper Harness
There are a lot of other things you need to know when swapping a z6 head on a 1.5 non-vtec block..
This is called a mini-me build!!
Read this!!
http://honda-tech.com/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
You are better off just dropping a full z6 swap in.. mini-me's are sometimes (a lot of the time) a bitch!!
Sign In
or
Register
to comment.
3) OBD1 Distributor
4) 4 wire O2 sensor
Read this!!
