Sound deadening/insulation
Hello,
I started working on sound/vibration proofing the wagon. My question is have any of you completely covered the inside with it?
I have already done the whole floor, every corner and under handbrake etc.
I wonder if I should also stick it on my roof and if I should only do the inside of my doors or also the outside.
Furthermore, I am interested in the over all effect of it when done. It is very tedious work so I want to ask before spending 3-4 more days sticking little pieces together.
I think you will benefit the most from improving rubber seals and leading/trailing edges for noise.
Still, does anyone have their wagon sound proof?
Hope this helps
Hope this helps
