Greetings and salutations.
I've wanted a 4wd Civic wagon for a long time and finally got one a couple weeks ago. 1988 rt4wd 6-speed, gold with 160K miles. Been in Raleigh NC it's whole life. Only a little surface rust around wheel wells and a couple dings. Immaculate interior looks like new. Has ALL the extra dealer options included. Unmolested and completely stock except for dealer installed non-Honda cruise control.
A question I have is whether or not it's okay to drive with 4wd disengage for the summer. I've researched extensively and know that people have done this but my concern is whether or not this will shorten the life of the viscous coupler. Seems that with 4wd disengaged, this causes the VC to work constantly and could over heat. I read that it should only be towed like this for 50 miles. That's probably a question for another thread. I've read a few threads about it on here already but this question doesn't seem to be answered definitively. Most people say it's fine but I'm not convinced... If it is fine to drive in 2wd mode, then I plan to use a bicycle shift lever and cable to fabricate an in-cab switch so I can shift in and out of 4wd on the fly. I realize that fuel consumption is basically the same. The reason I would want to do this is if I ever get a flat and need to use the small spare (this would stress the 4wd system), or if I ever need to get it towed, and just because it would be cool to do... It also seems to drive a little smoother in 2wd mode. I was hoping that while in 2wd I could reduce wear on the 4wd system but this doesn't seem to be possible as it's all gonna be spinning anyway, but idk. The 3rd gen 4wd wagons had a switch on the dash that allowed for the choice of 4wd or 2wd. I wonder why they did away with this feature? Maybe because it causes premature failure of the VC? Idk...
Super happy with this car! And happy to find this online community.
I'm interested in the cable for the RWD engagement. I currently have one I can't lock due to a broken bolt. Seems like it would be easy except for the terrible accessibility. Trying to avoid pulling the motor.
The less user interaction required, the fewer chances for mistakes. Make it idiot proof. Following that same train, we're developing driverless cars.
As for the cable, I was thinking of an old-school choke cable. Pull out and twist to lock in 4WD, twist and push in for 2WD. Anchoring and attaching the business end will be the challenging part.
