Misfire issues
My RT4wd has heavy misfire issues at lower idle with load, and misfires occasionally at all other RPMs. I have been dealing with the occasional misfire since I bough it 5 months ago.
The heavy misfire occurred on the first 70 plus degree day up here, when the engine was sitting in traffic.
I did a tune it when I bought it and adjusted the valve lash. It does need a timing belt. I'm leaning towards it being a valve lash issue.
Any tips?
Any tips?
Thanks! I'll let yo know how it turns out.
I have not confirmed the ignition timing since my light broke. However, the misfire happens after the engine is very warm, usually after sitting in traffic or about a half hour of driving. With the cooler weather rolling in, the misfires are less frequent. So it is definitely temp related.
I'm thinking it is sensing knock. What do you guys think?
You need to check that timing too. Where in NH are you? Im actually just west of Nashua a bit.
- oil in plug hole
- bad plug wires
The care ate plug wires until I put a set of NGKs on it. No problems for quite a while now.
When I bought the car last December, the misfire was rough. At speed it felt like someone slammed into the car. It has been much better since i replaced a bunch of parts and did the timing belt.
I'll located near Lee.
This seems to be a limp home mode? I also noticed the engine bay was very hot... likely the EFI is retarding the ignition. The car is not overheating.
I feeling the pressure to do the ignition timing this weekend. Any tips on doing that?
mine has a slight misfire due to sticking injectors
Ruled that out with new OEM injectors.
Engine light came on again this morning when it was cold outside! The wagon manual says to check the ECU for the LED flash count.... I counted 4 flashes. I can check what that means when I get home tonight.
I did retard the ignition a tad just for peace of mind. I would rather it be low on power than ping.
-more metal shavings and shards
-oil leak from the distributor (gasket is hard)
-shaft play
-shaft would bind when spun by hand
-wear marks on crank rotor teeth (smacking against pickup coil)
Regardless it this is the actual issue, the dizzy is being replaced. It's shot. Although, I have a pretty good feeling this is it given how a wobbly shaft would affect rotor positions. AND it'll fix my oil leak.. BONUS
New one is on the way, I'll let you know how I make out. Driving the VW MK1 in the meantime.
