rear doors won't open
As most of you know, I picked up a 91 wagon with rt4wd. I am having a problem with the rear doors. Basically I can't open the rear doors either from the inside or outside. It seems like the lock mechanisms are not releasing when the lock is opened. Is there any way to fix this without having to remove the door panel as I'm not sure I can even remove the door panels with the doors closed. Can I jimmy the locks open? Thanks!
my rear doors unlock/lock but don't open unless i push in on the door, pull up on the handle, then pull out. i've tried adjusting them many times and this is as good as i can get them.
good luck
This morning I tried playing with the passenger side lock. Basically I just opened and closed the lock and it eventually ended up unlocking all the way, allowing the opening of the door. Thanks for the tip. Now I need to work on the driver's side. And fix all the rust. And figure out how to get better gas mileage. But I'll save those problems for another post. Thanks again!
