Door Panel Seal (Plastic Sheet) Replacement
The plastic sheet behind the door panels is rarely reusable and the putty that holds it is usually hardened and useless. It's important to replace this seal with something to keep dust out of the increasingly scarce window regulators. After multiple unsuccessful attempts to glue polyethylene (Visqueen) sheet, I decided there must be something else. It came to me this morning. Tyvek house wrap! It's non-breathable, tough and can be glued. It's available 3 ft. wide by the foot on eBay with very reasonable shipping. I'm ordering some immediately, will try spray glue to hold it.
Has anybody tried this, or anything else?
Good idea, let us know how it works out.
Not entirely true, the plastic sheet is to stop moisture affecting the door trim and also to stop outside air coming through the door trim. I have used plastic drop sheets and duct tape to replace broken ones before.
Found some info that may help you
http://www.hotrodders.com/forum/basics-basics-moisture-shields-behind-trim-panels-161805.html#/forumsite/20624/topics/161805
Yes, I was aware of the moisture control aspects, but here in California dust is much more of an issue lately. :nightmare:
Good tutorial, I wasn't aware of the butyl tape.
I've been trying to avoid any of the commonly available tapes because they harden and fail.
The best sheet material I've used was tarpaulin patching material. The trucking outfit I worked for at the time had a flatbed division, and there happened to be a roll handy when I needed it..
Just thinking of other means to accomplish this, if someone were going for some better sound deadening capabilities. I have to imagine that aluminum backed rubber is gonna be a hell of a vapor/dust barrier.
How does the dust get into the door? From the window channel?
Dust comes in thru every conceivable opening (and some inconceivable ones). I've had clouds of dust drifting in thru my speakers when driving on back roads.
You could leave the plastic in place but your dynamat would have to run higher up the door, it weighs alot and if it came unstuck it would separate the plastic beneath it from your door frame (if they bonded)
Im accounting for alot of "what ifs" and talking out loud.
For example mr whoopee with the issue of water drainage, the plastic on the inner door frame gets stuck to a flat piece of the frame and its only way of directing water back to the inner skin and the drain holes is if its
A: 100% water tight sealed around the bottom and sides
B:fills up and tips over the edge of the lip on the bottom hole.
Probably easier to see what im blabbing about with this pic
Ah, there we go. The Dynamat I have used was a much thicker product. I guess I'm just behind the times (again). No additional plastic necessary with the installation shown.
It blocks moisture, dust, and pretty much everything. We put it on every spot we could.
Note the slot and hole and how closely the caulking passes under them. Also note that the caulking runs downhill to those two openings. This directs water on the plastic sheet down to the openings and back into the door, rather that letting it pool between the plastic and metal. I have ordered some sealing tape
http://www.amazon.com/dp/B006JFKMWG/ref=pe_385040_128020140_TE_3p_dp_1
and will follow the line of caulk closely when I attach the Tyvek.
