A Disadvantage to Disengaging RWD
Every year, after the snow melts, I remove the studded snow tires from my RTs and replace them with summer tires. Since the summer tires are not perfectly matched, I disengage the rear wheel drive. Yesterday was the day, swapped the tires, then got under the hood. When I loosened the "stopper bolt" that locks the selector lever, I noticed it didn't turn all that freely. I backed it out about a turn and a half, then switched the lever, rocking the car a little while in gear. After switching the lever, I started to tighten the lock bolt. Almost immediately the HEAD SHEARED OFF! This was not due to over tightening, it hadn't gotten that far. Anyway, I'm totally screwed now.
I'm working on a process involving a very long center punch and an equally long 5/32 left-hand drill, hoping to back the broken stud out. Does anyone here have any suggestions that don't involve pulling the motor? PLEASE!
EDIT: not counter-sunk - reverse drill bit.
https://www.youtube.com/watch?v=uIAAXTUcwRU
I've used that trick before with great success. Unfortunately, unless I can remove the selector lever, I will just end up with the nut and stud welded to the lever, making matters even worse. The access, as you probably know, is really bad. It's hard to even see. BTW, is that an Aloris tool holder in the pic?
That's what I meant by left-hand drill bit, it cuts in the reverse direction and, if I'm very lucky, will grab and back the stud out.
Either way good luck with the stud removal, keep us updated with how it works out
i used a piece of shelving and drilled 2 holes in it, and notched it for the speed sensor.
i used the existing hole for the speed sensor hold down to secure the strap into place.
it works great with no play. if i ever have the need to move the lever into 2wd i would have to take the bolt out and make a longer strap if i wanted it to be clamped down.
I like your creative solution. If I had the tranny out of the car, I would have no problem removing the stud as in message #2 above. I am currently driving in FWD without the lever being locked. I'm not worried about it jumping INTO 4WD. I suspect it would jump OUT under load, but perhaps not. I've been considering trying to rig a cable linkage that would allow me to switch in and out from the driver's seat, but I've ordered the hardware for an attempt at removing the stud.
