D15b2 to D16y7 harness
So I have a d16y7 in my wagon and Im trying to run it off of the stock ecu and wire harness is this possible
Also I am being told I have to switch to the d16y7 intake , I am running into difficulty with my alternator too, how do i go about splicing the different inlet?
The D16y7 is a OBD2-a
All the D15b2 parts should bolt right up to the D16y7
Yes you will have to swap the intake manifold alternator and distributor from the b2 to the y7.
Also use the b2 drivers side motor mount and motor mount bracket or the motor will sit kinda off..
Also use the y7 alt belt.
If I remember correctly the temp sensor wires were too short, so you will need to extend them.
I think that is it!!
and I read that the d15b2 alternator wasn't compatible for the d16y7
the forum says alternators are compatible from 88-95 my d16 came out of a 97?
PGM-FI dual point fuel injector means OBD-0 "Dual Point" are the key words.
In simple words it's like an update on the carb design however the fuel is injected electronically. It has only TWO injectors that deal with all the fuel, the cylinder that is in the intake stroke sucks the fuel available in the manifold. That's one of the multiple problems this system has, fuel is not distributed the optimal way.
If I were you I would convert to OBD-1.
OBD-1 MPFI
Multipoint fuel injection, which there is one fuel injector feeding each cylinder. 4 injectors..
It would be a pain to convert but it would be worth it in the long run!!
Better MPG, easier to convert to Vtec, ECU easy to tune.. Plus a ton of other pros to the OBD-1 conversion which I'm not going to list..
Anyway~~
You can still just bolt on the b2 intake, distributor and alternator on the y7 and run with the same ECU and wiring.
Everything would be the same except for the y7 head and block.
You have to use the b2 alternator, because the plug on the y7 alternator is OBD-2a, or you can buy a jumper cable and use the y7 alternator.
If you want to use y7 distributor, you can also buy a jumper cable. "OBD-2a to OBD-0"
Again If I where doing this I would think long and hard, doing a ton of research, listing the pros and cons on doing the OBD-0 to OBD01 conversion..
The only major con is the cost of the conversion and its time consuming..
Its really not so hard, you can buy a complete waring harness to make the conversion easier.. They just cost quite a bit!!
then wire that all up?
then use y7 intake?
y7 alternater
y7 distributer
and run the whole thing on y7 wire harness?
just trying to make sure im understanding
This jumper will have everything you need to wire it up
I would go with the D16z6 harness, because later you might want to slap a Vtec head on and run a P28 ECU
You could run a P28 ECU anyway, you just cant hook up vtec..
I wish I had made a DIY the last time I did the conversion..
Here is some lite reading to get you started!!
http://www.d-series.org/forums/diy-forum/39133-diy-dpfi-mpfi-swap.html
Keep in mind this DIY doesn't use any jumper harness, Jumpers make it much easier!!
Read this!! At the bottom there is a PDF with instructions!!
http://www.hamotorsports.com/obd0-dpfi-to-obd1.html
http://honda-tech.com/honda-crx-ef-civic-1988-1991-3/diy-dpfi-mpfi-swap-made-easy-2889205/
This one is good but, all the pictures are missing in the one
http://www.hondabuild.com/showthread.php?428-dpfi-to-mpfi-swap
Yes this one is for B20's, but it's the same principle
Also this is what you would have to do with out jumpers
http://www.b20vtec.com/forums/technical-information/436716-dpfi-mpfi-conversion-diagrams.html
no use the one thats in the car..
Although if you want it done right you could rewire the whole car whit a OBD-1 wiring harness from a 92-95 civic
What a pain the ass this would be!!!
This is the quickest, easiest, and cheapest way.
Civtec is correct!!
