Tokico Problems
So Im i just put d2 lowering springs on tokico blues that came off a 96 ek hatch somehow the front struts fit on the wagon, but my my back struts where blown so i want to get tokicos in the back but im running into some problems, people keep saying the tokico blues for a 1990 wont fit the wagon models and thats why they only give me the haatchback option so the real question is
"are 1990 hatchback rear tokico blues compatable with a wagon"???
Someone more knowledgeable than me is likely to chime in though, but that's my guess on why people would be saying they don't fit. That is unless they're just talking about the straight up bolt in factor of things, which I doubt that's a problem.
Yes, but it kinda depends on what springs you want to use. Wagon rear springs are extra long, and wagon rear struts have a low spring perch to accommodate the long springs. Switching to a non-wagon rear strut with their higher spring perch requires using a shorter spring... unless you want the ass end of your car jacked up high in the air.
I know it's not a true comparison given the compression that's on the springs, but since it's super simple popping the rear struts out, if they're not out already. I'd just side by side the new and the old and see if it looks at least close before bolting it all back up.
