rt4wd/crv diff bushings
i just used some 98 crv diff bushes on my 88 rt4wd, thought i'd share. didnt add it to the ef interchangeability thread because its not sedan/hatch/wagon related but if it belongs in there feel free to move the post.
crv's use four of these, the ones on the bottom arent even taking any load so they wont have any wear. crv left, civic right
rear mount, crv left and civic right, as you can see its exactly the same between models
rear harmonic damper, civic left, crv right.
the crv one is a little shorter and the locating tab is a little further out but when bolted in it sits exactly the same as the factory civic item
the crv diff mount bushings appear to be the same size aswell, i'll be ordering some of those off amazon soon and change out mine soon.
i checked out crv's from 97 to 04 at the wreckers and they all used the same bushes but the models from 00 onwards didnt have a vibration damper
hope the info helps
hope the info helps
I need diff bushings in a bad way now there is an OEM solution.
50713-SH9-010
50721-SH9-901
50716-SR7-J00
This part number: 50711-SH9-020
Actually all of the mount/isolator part numbers interchange except for that engine mount looking bit. The 50721-SH9-901 on the CR-V is a 50721-SH9-010 on a Wagon.
For Valentines day I would like....
This info needs to be added to the interchangeable list!!
