B-series TB on D-series intake manifold
i have a D15B2 with an MPFI swap using all civic Si intake parts. i was wondering about one thing though.. i know the B-series throttle body fits on a D-series manifold, but is it bigger then a D-series? so if i swap out my D TB for a B TB will i get any HP gains at all? or possibly use it later on on a Skunk2 intake manifold....
input?
input?
I'm currently putting the same setup together pretty much but i have a KBB TB that is the same size as the 1st gen Skunk2 IM i have but i still have yet to bring the head to a shop and have them port match the head to the IM.
On d-series.org I've heard it claimed that the throttle body will not be the limiting factor unless you have a pretty decent all motor build, just food for thought.
Also on portmatching, won't that interrupt the velocity of the air as much as it will help? You're going narrow > bigger > narrower/valve. By going narrower to larger you will lose velocity. I've also heard it said that the little step acts like an anti-reversion feature. I don't know, just something to think about.
I thought this was the case, but didn't want to say so until I looked.
eh, i just like shiny things
I believe the point of port matching is to keep the velocity consistent. if you'd imagine, putting on an aftermarket IM with a larger inlet than the TB outlet, the flow of air would then be disturbed from the difference in diameter between the two openings. So i guess imagine blowing out of a straw with a plate at the end with a hole smaller in diamter than the straw itself verses blow out of the same straw with the plate's hole being the same size.
Am i gettin you right?
You're right about the throttle body, I would try to smooth out the step there. For some reason my mind jumped to portmatching the intake manifold at the gasket/head, which a lot of people do. So my rant was mainly directed at that, not at port matching the tb. Sorry for the confusing off-topic rant...
