Warm idle tach reading 0.
Hey gang,
recently my tach has started reading 0 at warm idle, if i give it a little throttle, it will jump up (i assume to where it should be, but who knows)
car is running fine, if i had no tach at all, i would never know there was a problem.
Is this a distributor problem?
Thanks.
Thanks.
years of being bent in the same position and always vibrating could easily be your tachs demise
someone correct me if im wrong but the blue wire on the left big plug on the instrument gauge is the coil which controls your tach and on the distributor its the blue wire assuming your still obd0 from your previous comment above about obd1 in the future
