What radiator works in an RT wit han automatic.
Hi I need a new radiator for my car and I'm having a heck of a time finding one that has the same size core as the original. I bought one off ebay that was supposed to be a direct fit replacement but when I got it I noticed that the core was only half the thickness of the original. I've been looking for one that will offer the same cooling capacity but all the ones I'm finding seem to be of the 5/8ths thick single core type. I found dual core all aluminum radiators on ebay but they are all for manual cars and from what I can tell I would need to install a separate oil cooler to make it work. Is there a simpler solution to replace the radiator in my car? Is this 5/8 single core adequate? What do you guys run?
Tried a concerto radiator? Same thing, twin row with oil cooler underneath for the auto version.
Thought about getting your one reconditioned? More often than not a better option then buying a second hand one
Compared to a DA radiator (not sure if you get D-series DA's either...)?
This one I got has the tranny ports, I guess it was cheap enough that sending it back is hardly cost effective so I'll just throw it in there and see if it works, I'm sure it will be fine until the summer anyway. I just can't believe that there is no equivalent replacement available for my car. Even the more expensive ones from Koyo and CSF are a single core.
DENSO Part # 2213221 {#19010PM3901}
$55.79
VARIOUS MFR Part # HO3010164 {#19010PM3305, 19010PM3901, RAD886}
$58.79
PRO Part # 8010886 {Click Info Link for Alternate/OEM Part Numbers} Plastic Tank Aluminum
$63.79
SPECTRA PREMIUM / COOLING DEPOT Part # CU886 {Click Info Link for Alternate/OEM Part Numbers}
$66.79
VISTA-PRO Part # 432106 {#886, 9670, 99670} Ready-Rad; Mounting: PIN
$68.79
SPECTRA PREMIUM / COOLING DEPOT Part # CU10 {Click Info Link for Alternate/OEM Part Numbers}
* Stocked in outlying warehouse--shipping delayed up to 1 business day
$77.79
VARIOUS MFR Part # HO3010165 {#19010PM3902}
* Stocked in outlying warehouse--shipping delayed up to 5 business days
$90.99
