Yes engine bolts right up ,no tranny mods needed. You have to take the motor mounts off your old motor and put them on the new motor .if you are not pulling the engine and transaxle as a unit , you need to take the cover off to undo the flexplate to torque converter bolts .the engine cannot go up and out with the torque converter on it .You can run a Z6 wth the intake and exhaust and stock wiring from your old motor .
