I also just filled mine with a product called Fusor. Also I've heard that some windshield urethane work well. they give a little more than a solid filler.
Grifty, would you mind posting up part number(s) and the contact where you made the request?
Here in Australia you're able to submit a remake request through your local dealer, well atleast mine that is. Commonly known as consultation parts, the dealer submits the request and waits a few days for a response from Japan.
Here is my invoice of when i ordered the rear diff bushing and shifter bushes, you need to remove the HO- from the front and that's the part number.
I can check Japan stock for you guys for all 5 rear diff bushes, usually if they no longer have the part in USA you may be able to get it directly from Japan.
Honda has discontinued them. None available worldwide
What type of urethane and where did you get it.
Excellent. Great idea. Thanks
Guess I just got lucky then, I put in a remake request for the very back diff mount and they remade it for me.
use a windscreen sealant, just make sure all of the bushes are clean of dust and dirt before applying it
Option #2: http://www.civicwagon.com/showthread.php?9589-Rear-diff-bushing-mod-get-rid-of-that-quot-thud-quot-sound
They can be ordered from Amayama Japan.
The screenshot shows 6 different parts, I believe there arent any differences but I double checked stock on all the part numbers they had listed.
You'll only need part numbers 1x50721SH9901, 2x50711SH9900, 2x50713SH9010.
Parts diagram can be found here: http://jp-carparts.com/honda/partlist.php?maker=honda&type=CIVIC%20SHUTTLE&cartype=16477&fig=B&fig1=1905
