tune up time
tune up time has arrived for my wagon, i have new ignition wires, spark plugs, fuel filter, and valve cover gasket set. also i have the little o-rings that go under the rocker assembly. my question is: when taking off the rocker assembly to put the new o-rings in do i need to do a valve adjustment after putting it back on the motor? or if i dont move it around too much should it be fine?
Now, in reality you can get away with leaving them alone. Everything should end up the same.
