head part identification help 1991 1.6 engine
When taking off my head to replace the gasket this fell out and I am not certain where it goes. It is a round metal cylinder that measures approximately 11mm outside, 9.85mm tall, 6.8mm inside diameter. It looks like a thicker guide pin for the headgasket but it is to small for a head bolt to fit through it. I have looked at the Honda parts manual but I cannot locate which part this is.
Does it go over the oil jet? It really does not fit over that nicely either.
direct link in case the attachment does not work,
http://m.imgur.com/gallery/wsqoy
1991 civic wagon rt4wd 1.6 stock engine.
What makes it strange is that when I pulled off the head it was just resting on one of the pistons, so I know if fell from something. I cannot see it fitting anything from the PRG-FI intake unit to the head top or bottom, or the top of the engine block. It was oily, but inside the engine oil, not caked on outside oil.
If I misunderstood your reply, please let me know.
Thank you-
503 is correct
Same thing happened to me when I did my head gasket. Thy're not that expensive new from Honda. Just replace them. Though mine were in much worse shape.
Does that make better sense?
